And the answer is:
To beat the s*** out of it, as most people will do.
Seeing this is the most popular drift car by far it isn't uncommon.
I am a huge advocate of proper oiling system on an RB, but this seem to be an early GTR mostly.
Although the narrow oil pump drive on RB cranks from 89-93' can benefit from the wider drive collar for sure.
Its the ones that will be pounding the car sideways, off the rev limiter that will really benefit from:
-Chromoly Crank collar
-Oil pan baffle
-Head-drain modifiction
-Chromoly gear replacement. (Good for those who have a stock oil pump)
In retrospec, this is way better then shelling out 1200-1800 buck for an RB oil pump. That's the beauty of a gear-set.
And I don't know why a good machine shop couldn't mill out some chromoly gerotors, because essentially, that's all they are.
Here's a local Maine Gerotor Manufacturing plant.
http://www.gerotor.net/
Modified by GTRs13 at 4:05 PM 4/8/2009
