Cpt_Impossible »
https://forums.nicoclub.com/cpt-impossible-u43114.html
Fri Mar 09, 2007 8:17 pm
System was bled thoroughly every time the coolant was changed. I filled, bled with screw, ran, bled with screw, ran, bled with screw, ran, bled with screw, ran, bled with screw,... and then jacked up the car and ran while bleeding, then filled in the bleeder hole, then ran some more and bled again.
If there is air in the system car overheats like crazy, when the car is bled thoroughly its only overheating on the freeway a little but a little overheating is a little too much because it means I can't boost and sometimes have to pull off the freeway.
Right now the bumper holes are cut, and the paint is done, just waiting to dry.
