Thanks for the input.
OK, after viewing those pictures, i've got an idea of what's going on. Here's my question:
Would it be possible to fab custom brackets to hold the radiator approx. 2 inches back *and* 2 inches down from its current location? That way, the IC could be mounted where the radiator is now, and the output connections on the IC would be at the top corners of the radiator (allowing room for connections, of course).
Alternatively, if you have a recommendation for a junkyard radiator that would fit between the IC connections (about 22-24 in?), i'd like to hear those as well. Some mumbling 10,000 websites ago seemed to indicate some Datsun pickup radiators, for example?
I'll be running cooling fans appropriate to the application, with aluminum panels connecting each side of the radiator and the intercooler to guide air flow.
I want to mix things up a bit - see if I can perhaps contribute a bit to the collective DE-T knowledge base out there.
EDIT: The IC is both an engineering project and a safety margin. A turbo system is not complete without some sort of IC, in my opinion.
