Altima 07+ (Coupe and Sedan)opekone_1988 wrote:Very Very Interesting review.. Might just get it myself.. If you don't mind stating, how much did you pay?
Placebo Effect:08coupedriver wrote:Well I installed the kit for my V6 A/C and I have to say Im pretty satisfied with the kit,
the install was pretty easy, My mpg went up slightly, my car starts up better, my HIDs power up really quick now, and I even got my "auto" light feature back, where I can leave the car in "auto" at night and they power up perfectly. My throttle response improved a little as well
overall its a great product and i would recommend it to anyone
I am just stating the things that I noticed after I installed it,some of the things maybe a placebo effect but some of the things are not, I know for a fact before I installed the kit my 4 Hid ballast wouldnt light up when i left the car in "auto", now they do and they do it quickly, and my gas computer was reset after a couple hundred miles without the kit, then I installed the kit and I resetted the computer on the dash and drove the exact same commute and the mpg's were improved.Throckmorton wrote:
Placebo Effect:
An improvement in a person's car regarded as the effect of the persons's belief in the effectiveness of the product purchased.
I'm surprised that your garage door opener doesn't operate at warp speed also.
In my opinion, these so called 'Grounding Kits' might assist you if you had an electrical drain on your car's 12 volt system, such as a super powerful amp for your sound system.
Try this simple, but effective grounding test.
First, a disclaimer: Not responsible for injuries sustained by the person and or persons simple minded enough to do this scientific test at home.
Holding a small metal knife in your right hand, and standing on only one foot, insert one end in a 120 volt electrical outlet. You will receive an electrical shock of 120 volts, as you have completed the circuit.
Now, get a second small knife, so that you are now holding a metal knife in each hand. Stand on both feet, and insert both knife blades simultaneously into the 120 volt electrical outlet. You will receive an electrical shock of 120 volts, not 240volts
Why not? Why weren't you shocked with 240 volts? You had a better ground for the second test, didn't you? You completed the circuit during both tests, but the fact of the matter is that you can not get more voltage out of a system simply because of multiple grounds. 120 volts was all that was available during both tests.
Same with the car. A 12 volt battery, fully charged, will be a little over 14 volts. You can install 100 feet of grounding wire, and you still have no more than 14 volts available.
If someone, using scientific principles, can prove to me that the Nissan Altima comes from the factory with an inferior system to ground the on-car electrical system, I would like to see it.
Wow...where to start.Throckmorton wrote:
Placebo Effect:
You lost my kit in your garage somewhere? Or one of the other company's?Desire1314 wrote:Wanting to install my kit in my A/C, but i'll prob just wait until spring comes. Plus i have to find it, its lost somewhere in teh garage...........
