mkory wrote:How do I open up the wastegate to check that the spring inside is the correct one I want? I bought the turbo used, and I want to make sure.
along the sides of the wastegate you'll see a good amount of those hexagon bolt things. i forgot whats it called. but you basically just take a hexagon Key thing or whatever its called and unscrew them all. the top should pop right off (and i literally mean pop off because of the spring so watch out when u take off the SECOND to last bolt because all the pressure will be on that last one so HOLD it down) and then you will see the spring. its nothing special, just a spring inside
BUT. that is really not the way to check if its the right spring, unless you have another spring to compare it with. the correct way to check what spring you have is to hook up an air compressor directly to the side port where you would usually have your vacuum source. keep adjusting your air compressor until you start to see your piston rising. but if you decide to hook it up WITHOUT taking it off the manifold...put your hand on the wastegate's dump and feel when the air comes out. its probably gonna be hot though lol...
anyone else got a better way?
