94_240sx »
https://forums.nicoclub.com/94-240sx-u26401.html
Fri Dec 08, 2006 5:14 pm
Nope! FSM supplement doesn't have any numbers for bow locations. I measured my vert. I did very carefully, so I guarantee that numbers are accurate. They show space between bows, not from the center of each bow to another. 20 inch is from #4 bow to tip of black trim. It was 14, 14, 15, and 20 even!! I was surprised to see that. Maybe someone measures his/hers and confirms that those numbers are correct. Just let us know if you need anything.
BTW, quarter window assembly is even worse. It can move freely up, down, left, right, in and out. It's like floating in the air. Slight angle change messes up alignment. I spent long time to make them look perfect again, so I know your pain...
