Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Mon Aug 30, 2004 7:28 am
If you search, you will find that several people had that problem. Did you wire up the air regulator to the fuel pump relay?
Starting has nothing to do with the O2 sensor, btw. The O2 sensor is not used until it heats up to operating temperature. Even a heated sensor takes almost a full minute to reach operating temperature.
