float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sat Feb 11, 2006 6:45 am
Ok, listen up...1st: NO TEFLON TAPE ON "AN" FITTINGS!!! They don't seal on the threads, they seal at the inverted part. 2nd:The stock taka oil line won't work with the stock CA18 90* block outlet fitting. The Taka line comes with an adapter with the "male" part of the "AN", and the 90* adapter coming out of the block is "male" as well. This won't seal. I stripped mine out (that's why I got the taka lines) so I ended up getting a new 90* from the parts store. It was, I THINK, 1/4" pipe thread, by 1/8" AN (male)? I actually just took the 90* and the taka line down and found something that would thread into the taka line WITH OUT the adapter. To do it this way, you won't be using an adapter. Now here is the crappy part. The block is actually a metric pipe thread, whereas all you'll find is standard. The thread pitch is the same, but the diameters are different. I went and got a drill and tap that would make the new 90* work and slightly enlarged the opening in the block. Your other option is try to order another adapter that will allow you to use the stock 90* block fitting, but I didn't want to wait. 3rd:When they talk about teflon coating, they are talking about the INSIDE of the line. You need teflon on the inside of the oil line because it's just plain ol' rubber in there and the oil will cause it to deteriorate. The coolant lines don't have it because the coolant doesn't deteriorate the rubber. At least not like the oil does. 4th:The banjo fittings HAVE to have crush washer to seal.
