Double E wrote:the effort made to increse HP through less piston ring friction. What I understand from others here (Szhosain, I think) is that power was gained by reducing the piston wall-to-piston ring friction.
Yes, that is what they did! Looser tolerances, so less friction and more horsepower ... (better way of saying it: less "wasted" on overcoming piston-wall friction).
Double E wrote:To me, that means that break-in procedures are vitally important and that synthetic oil (having a superior viscoscity) may get by the rings until heat builds up enough in the rings for the tolerance to close and make a proper seal.
Yes, I agree ... a good break-in process on these engines is essential! I strongly recommend that the engine be run on a good dino oil for the first 7,500 to 10,000 miles. Something like Castrol GTX or Chevron Supreme 5W-30 in that period. Then, you can switch to Synthetic.
FWIW, if anybody wants to stick with dino oil permanently, using a 3750 mile OCI, that is perfectly fine too!
Z
