Those running Tec II on SR's...........
Imissmyturbo
Car: Car's, Turbo's, sking
Are you running your engine without the stock SR ECU? I have a 92 SE that I am going to install an SR with a TEC II. The SR just has a cut stock Harness without an ECU. I have all the nessary sensor and pickups for the Tec II. Should the stock KA ECU be reatained for any resound? Charging? Fuel pump? Can the engine be ran just off the tec II without and other stock ECU?
I H8 UR DSM
Imissmyturbo wrote: Should the stock KA ECU be reatained for any resound? Charging? Fuel pump? Can the engine be ran just off the tec II without and other stock ECU?
1. no2. huh?3. huh?4. yes.
