Those of you Running the Stock RB20 Lower harness have questions with pics
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Ok I was just looking at my car and noticed that I was missing a plug on one of the lower harness near the Altenator harness. can someone tell me if they are pluged in on yours?
Yellow4g63
Pic #3 is the one that goes to the Altenator
#2 and #1 I have no idea where they go.
s14-240
just use the Ka lower. I followed the steps posted by Wolfgang, and it worked great. Then you can use the ka alternator as well.Walter
Yellow4g63
s14-240 wrote:just use the Ka lower. I followed the steps posted by Wolfgang, and it worked great. Then you can use the ka alternator as well.Walter
Thanks for the info. But still no help.
theXfiend
Car: 1992 240sx coupe SE w/ rb25det
its kind of a bad picture, can you get anything better? plug #1 looks like it goes to the alternator itself, unless that one is plugged in in which case it goes to the thermostat on the radiator i THINK (just let it hang)
is number 2 wires? or cables,
if you can get wire colors we could probly help more.
Yellow4g63
#2 I think was in a plug. blk and blk/green. I'll try and get some better pics when I get home from work.
Yellow4g63
Couldn't get anymore pics. I sold my camcorder to my dad and bought a another one that had to be sent back to Sony. Any help? I tried to plug in the KA harness except the ground wire cause that was cut (can't rem why it was). I used the ground of the RB harness and still no game. I know my altanator is good because I tried it on my friends RB25 and it worked.
theXfiend
what ground wire? the one for the Alternator? if so you can just run a new ground wire direct from the alternator to the engine block. also make sure that the plug with 2 wires is plugged into the alternator and those wires are hooked up to the KA fuse box.
Yellow4g63
theXfiend wrote:what ground wire? the one for the Alternator? if so you can just run a new ground wire direct from the alternator to the engine block. also make sure that the plug with 2 wires is plugged into the alternator and those wires are hooked up to the KA fuse box.
GOT it. Your words went into my head. I looked over my wiring on the RB harness and I Had the red/white wire going back into the KA lower harness. I put it back to the fuse box and she charges with the RBlower harness. THANK you very much for your info.
