amolao »
https://forums.nicoclub.com/amolao-u11541.html
Fri Feb 09, 2007 4:28 am
Bud, dont make it too complicated. These are two different things. You set TDC everytime you take ignition off, work deep inside engine, replace timing chain, replace oil pump,etc. This is "mechanical timing".
Your 20 degrees is the actual "operating" timing. This is what to you set your engine while using a timing light for top performance. You do need to be have correct TDC in order to have achieve your 20 degrees. If you are not in TDC you car will not start.
