This will make u think twice about turning up ur boost with stock side mount !
cdoyle360
ok my friend was running around 15 pounds on a stock t25 with stock side mount, 255 fp, pretty much stock sr20det... ok will we was doing a pull just messing around and he was in the top of 4th and then white smoke comes pooring out of the bottom of the car. He told me the car shut off as soon as it happen. we pop the hood and there's oil everywhere , the dip stick got blown almost all the way out, but there wasn't any signs where oil could come from besides that.. we turned over a couple times and it sounded like there was no compression... we pulled the plugs... cylinder 1 look like detonation.. the spark plug was not black at all and the tip of it was kinda chiped/scrached off. cylinder 2 3 4 was full of oil.. which is not good... we need some of ur opinions.. we think that it might have jumped timing and when that happen the cam shaft sensor would make the engine cut off.. but how would the cylinders have oil in them?
It sill turns over fine with no knocks we can here.the boost was cranked up but it should be know where near breaking internal wise.Cylinder 1 could have detnat when all the vavles where closed and when that happend it had no where to let the pressure out so it blew off the dip stick and runind the rings in the other cylinders..
Theres a couple more things.. we just wanna make sure we have a good start so we can figure out what went wrong.. well no f***ing flamming for those that wanna be faggits
Tore it down today scroll down and check pics.. :D
cdoyle360
Ohh.. my god.. check this s*** out lol first thing we did today was take off the vavle cover and check the timing... it was perfect... next step was compression test... this is where it got bad... cylinder 1 30 psi cyl 2 0 psi cyl 3 30 psi cyl 4 0psi.. lol wtf??? rings are gone.. so we tear down to see how bad it is.. and what went wrong .
so we found out that cylinders 1 an 3 leannnnned out hard .. so yea there we go
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Sounds to me like you were TRYING to blow it up.
15 psi with stock injectors and stock fpr on a turbo that can handle 14psi max.
Side mount too, ouch.
Nice, Thinking will do you good next time.
(I know its not you, its your friend but you know what i mean.)
cdoyle360
not my car :D
OM3GA wrote:Sounds to me like you were TRYING to blow it up.
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Idiots.
cdoyle360
this s***s funny as hell lol we was laughin as we was pulling it apart.. lol
OM3GA
what was that lol.
At least you had fun.
cdoyle360
OM3GA wrote:what was that lol.
we new what happen just didn't know how bad it was.. that stock side mount got in to heat soak mode and just shoving hot air into it inside of cold and it pretty much got to hot lol
OM3GA
Yeah but damn sucks to blow that engine unless he wanted to swap anyways.
cdoyle360
OM3GA wrote:Yeah but damn sucks to blow that engine unless he wanted to swap anyways.
the guy has money we gonna rebuild it right. with some over night parts from .. japan.. lol
simmode1
Car: Red '95 S14
More evidence that not even the "invincible" SR is foolproof...
Razi
Car: Moo
15 psi on stock injectors?
s13-t
Car: s13 pig nose w/blacktop sr20det
Holy $hitwell tell your friend to learn from his idiocy.
Start a build thread so we can see these parts he wants to rebuild with
OM3GA
lol you would quote the FnF lol
drewce
lol wow and good fnF quote lmaooo
kouki munster
Car: 97 base 240
simmode1 wrote:More evidence that not even the "invincible" SR is foolproof...
Unfortunately no engine is idiot proof.
EnjoiNismo
Car: 93 240sx
If your friend has "money" why would he have a side mount?
simmode1
Car: Red '95 S14
kouki munster wrote:Unfortunately no engine is idiot proof.
You got that right. But that doesn't stop ppl from talking about engine 'X' like it's some kind of God-motor.
TheBlaiant
Car: Slow40sx
Instead of wasting the money on that lame SR you should get an RB or JZ!
cheezy240
Car: 1990 RB20 Hatch
Ha damn that sucks, but at least yall were laughin when you took it apart, But I feel the same way about the stock injectors, 15 p.s.i?
But at least it was fun! I don't like sr's anyways so I think it's funny
This is that ashton kid btw
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
eeeeeeessssssssssssaaaaaaaaarrrrrrrrrr
S13 KID
Car: 91 240SX S13
Exactly! He should of had a fmic in the first place if he has so much money...Personally I wouldn't even turn my head to look at a boost controller if I didn't upgrade the surrounding parts needed to make it run properly and handle the boost.
cdoyle360
sad thing is.. only had the car for 2 days lol! he was getting a fmic but.. car didnt last that long
xX RB Xx
Car: SE3P, FC3S, FC3C.
Hopefully, lesson learned.
93sivliaUsdm
Car: 1993 240sx coupe sold
1990 240sx hatch DE swap
wow nice job lol kinda sounds like my buddy, he had a fully built type R motor in his civic that already had 12:1 compression, put a turbo kit on it and the wastegate was set at 12 lbs (unknown to him though it was at 7). he ran it on 93octane with stock injectors and blew his rings and destroyed his pistons
chicos240
Car: 1995 240 SX
Dude, this is awesome. Awesome because he had fun, and it blew up. This is what these cars are for, fun, and learning. Now he gets to really learn his engine and rebuild it. I am glad you are there to help him along and influence the rebuild. Have fun with all the work you have ahead of you and don't forget to make him read the FAQ stickies with power recommendations, that way he will be well informed about boost settings!
cdoyle360
[QUOTE=chicos240]Dude, this is awesome. Awesome because he had fun, and it blew up. This is what these cars are for, fun, and learning. Now he gets to really learn his engine and rebuild it. I am glad you are there to help him along and influence the rebuild. Have fun with all the work you have ahead of you and don't forget to make him read the FAQ stickies with power recommendations, that way he will be well informed about boost settings![/QUOTE
hell yea i have an sr as well to.. but i have a tune for 15 pounds and fmic..ect... so doing this rebuild is just gonna make me that much better with my motor
simmode1
Car: Red '95 S14
chicos240 wrote:Dude, this is awesome. Awesome because he had fun, and it blew up. This is what these cars are for, fun, and learning.
I guess thats one way to look at it. I prefer to learn from the well documented mistakes of others and do it right the first time rather than blowing up a $2000 motor and laughing about it.
But thats just me...
DMan II-40
Car: 1995 240SX SE
Agreed.
I take my time in modding my car for three reasons:
1. I read a lot to understand2. Plan for my needs3. I have no money for my plans
But one can dream, and I believe eventually and slowly over time I will get my car where I want it to be.
SirSilvia
Car: Sold both my babies
That has top be the worst I've ever seen lol. good show sir
now rebuild it
