This turbo is prolly too big for a CA, right?
slownslurious
Garrett GT25/40R TurbochargerTurbine- Wheel: 53mm w/ 62 Trim - Housing: .64 A/R- T25 Flange
Compressor- Wheel: 60mm w/ 60 Trim- Housing: .70 A/R
Someone on the board is selling this for a reasonable price, I'm guessing a 2540R .64 is probably too big to get streetable spool on the ca?
Florida240sx
What is you hp goal and what are your mods?I think it will work fine, just might not be best for your goals.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
slownslurious wrote:Garrett GT25/40R TurbochargerTurbine- Wheel: 53mm w/ 62 Trim - Housing: .64 A/R- T25 Flange
It will be a little laggy, but if drag racing is your thing, it will work good. Ought to know that it won't work with the stock manifold. The 25/40R has a huge T04S compressor housing.
slownslurious
I want to keep the stock bottom end, don't want to have to run higher than 93 octane, and would like spool by 3500-4000 rpm.I don't really care about the power level, anything over 250 would be really fast. I don't race much and when I do its autocross.
c-rad
Spool is more like 4500-5000 rpm. This is probably not the turbo for you as it more for the 375-400hp level.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
i bought a .86 version for my car. way to big. sold it and paid for a complete t3/t4 50trim setup. Masterpower 50trim, Turbosmart Ultragate, and a logmanifold. now one of these days ill actually get to put it on my car.
slownslurious
yeah after reading everyones responses I had already decided not to use it, I want something smaller and more responsive. I plan to eventually add cams but even then from what I understand, the stock rods aren't going to want to do much more than 7500 rpm without giving me trouble, and spooling after 4000 rpm just doesn't give me enough fun room.:-)
Dattebayo
the .70 A/R might be a bit much.
I would go for something along the .6 range for good non-laggy power... its not total overkill though.
Not_a_sr
get a 50trim with a .48 A/R on the exhaust side
CA19DET
MK1 Cortina runs this turbo with teh .86, full boost not till 5k, but he runs 11's i think..
