This Sucks
zion
Car: cars, guns, the usual
Well since I have been taking so long on rebuilding my SR, re-doing everything on it. I have seemed to have lost the Bolts for the Valve Cover (all of them) and the whole oil pan assym. Does anyone know where I can get them? Can we get them through Nissan USA dealers or do we have to get them from JP. Or if anyone has some that they would care to sell/give :ylsuper me that would be awsome. Thanks for all the help. As of now I am stuck.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
i dont see why the hardware from an infiniti G20 wouldnt work.
G20's use the SR20DE. the hardware is most likely identical.
zion
Ok cool. so i guess my next question would be if I can just walk up to a Nissan dealership and get the bolts or is it off to the junk yard again?
Nathan
You should be able to get them at the dealership. OR, you could just measure what length you need, then get the right size. Just screw in another bolt or screw until you find the right diameter and thread pitch, then head down to lowes and pick the appropriate bolts up. Probably easier to jsut go to the dealership though...
thes14project
Car: Thinking my friend and I have mechanical skills
wait, you lost the bolts to the valve cover? not the nuts?
zion
Yeah, I have the nuts and the rubber inserts I just dont have the studs. Oh and by the way if you go and look for the studs at a dealership for a 1991 Sentra SER, they are about $180, I about fell over when he said that. There has to be another way!!!. :help . Anyone else have any ideas?
loudbay
Car: duh
GET BOLTS WITH the same threads as the studs, and bolt the vc down to the head... i've done this with other studs, just find one that is shorter, so you can get it tight with out hitting the bottom of the 'threaded stud hole'
loudbay
Car: duh
um..... i didn't mean to say stud hole
thes14project
try ace hardware
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
zion wrote:and the whole oil pan assym.
you lost the whole bottom of your motor? :eek:
http://www.sr20store.com for used sr20 parts
zion
LOL. I had lost the bolts to the oil pan assym. but I have recovered them. The motor is out of the car and am doing all the build up like you did (J-Spec.). Lucky for me I have found those and got the valve cover bolts. Man I was stressin. lol. Thanks for all the imput, Found out really how expensive the dealer is.
zion
sgpnismo
loudbay wrote:GET BOLTS WITH the same threads as the studs, and bolt the vc down to the head... i've done this with other studs, just find one that is shorter, so you can get it tight with out hitting the bottom of the 'threaded stud hole'
gloryous, my valve cover studs are all ****ed also, never thought to just bolt down the valve cover. me need :help
