This stinks man!
marleyfan
Car: Black Versa SL, CVT. Tech Package, 35% Tint, Window Visors, Spoiler
Ok, so my cat was in a fight and needed to go to the vet (but you should'da seen the other guy). On the way back she peed on my passenger seat. Any suggestions about how to get rid of the smell??? I used my carpet cleaner and soaked it with Febreeze but it still smells like cat pee. I have the SL so it has the memory foam. If anyone has been successful at removing cat pee smell from a car please let me know.
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
This happened to my favorite easy chair. Here's what I did; First, steam clean and vacuum the upholstery several times. This will kill any bacteria that is left over. Second; buy a bottle of Febreeze (for pet odors), remove and throw away the spray head, and dump the entire bottle into the seat, being sure to let it soak in before pouring more onto the seat.
If that doesn't work, call an upholstery shop, or sell the car.
Woody64
Car: 2008 Nissan Versa SL 6-Speed
I am not sure if this is possible, but I have this recipe of sorts that I use of my dogs when they decide to fight skunks and get sprayed, it neutralized the odor. The only thing is it involves peroxide, which I believe bleaches fabrics. So if you could get the seat cover off I suppose this would be an option.
Tbl Spn - Dish SoapOne Bottle - Hydrogen Peroxide2 Tbl Spns - of Baking Soda
Mix vigorously, and apply. Usually takes 2-3 washes with my dogs, not sure with a seat. But it is a relatively cheap alternative to some pet odor cleaners. Not sure if this even helps at all...Good luck
Modified by Woody64 at 7:14 AM 8/29/2008
brainguyus
Car: '12 Nissan Murano SL
'08 Nissan Versa SL
'67 Lincoln Continental
I took my cat to the vet once without using a carrier. He wedged himself under the front seat and peed all over the carpet. This was before febreze and similar products. A good scrubbing with carpet shampoo and several coatings of baking soda (and leaving the windows cracked for a few weeks whenever possible) eventually got rid of the smell.
I've read good reviews on these, but I've never used them myself.
http://www.urine-off.com http://www.naturemakesitwork.com/home/index.php
Invest in a cat carrier.
marleyfan
Thanks for your replies. I'll see what I can do (short of selling the car).
Scuba Steve
Car: 2007 Nissa Versa 1.8SL Technology Pakage 6 Speed, Black
marleyfan wrote:Ok, so my cat was in a fight and needed to go to the vet (but you should'da seen the other guy). On the way back she peed on my passenger seat. Any suggestions about how to get rid of the smell??? I used my carpet cleaner and soaked it with Febreeze but it still smells like cat pee. I have the SL so it has the memory foam. If anyone has been successful at removing cat pee smell from a car please let me know.
Nissan Versa's DO NOT HAVE MEMORY FOAM!"
BBISHOPPCM
Than Nissan can be sued for advertising it has having memory foam in the front seats.
Scuba Steve
I love to see that advertisement....can you post the link or youtube link?
Andrews Chalmers
Car: Versa '07 SL CVT
Go to Petco and get an enzyme cleaner.
marleyfan
From car-reviews.automobile.com "Then there are the seats themselves, which are stuffed so fully with memory foam that they look to be bursting at the seams, but provide insufficient support." full article here: http://car-reviews.automobile..../2859/
or
Another thing specifications don’t tell you is that the seat pads in the Fit are far thinner than on the Versa, or that the Versa uses a half-inch thick layer of memory foam in its oversized seats to help with long-range comfort. Full article: zer...ote=1
Other references to the Versa's memory foam seats: http://www.carlist.com/newcars/2007/ncr ... s/...t.asp
I guess they are all making it up.
Scuba Steve
or
I like to see info from Nissan, third parties sometimes get there info screwed up....... If the Versa had memory foam, don't you think Nissan would want to advertise that feature? It's to their selling advantage. I also have copies of dealer car info in a binder showing many things that the Versa has...I'll will post them up when I have time. But they covered everything inside and out and nowhere does memory foam show up.
frankoV
Car: 2008 SL Sedan, Magnetic Grey, CVT
from the brochure:
you need a seat that appreciates your individual shape. That's why Versas' king-size front seats feature sculpted panels for custom-fit support. And with seat bottoms made of cushy double-thick foam . . .
Scuba Steve
you need a seat that appreciates your individual shape. That's why Versas' king-size front seats feature sculpted panels for custom-fit support. And with seat bottoms made of cushy double-thick foam . . . [/QUOTE]Dealer binder.
[QUOTE=frankohabs]It's say's double thick foam, not memory foam, it's totally different materials.
Slither
We have to re-examine the new 09 bigger Fit - ein grosser Fit?
Due mid-September.
marleyfan
Whatever Scuba Steve. The only reason I mentioned it is that it may have made a difference in the cleaning process. Can you say conclusively that the Versa SL (2007) does NOT have memory foam? How do you know? I have provided several references which indicate that it does. The fact that none of them are from Nissan does not mean they are not correct.
oxtsc64
Car: 2008 Nissan Versa S, 1995 Chevrolet Camaro Z28 Convertible, 1998 Toyota Tacoma
There are several products that use enzymes to kill the bacteria from pet urine. This removes the stains and the smell. These products work. Good luck.
bdu
Car: 2008 Nissan Versa SL HB
This is why I always use a carrier when I take my cats to the vet. Also, I line the bottom of the carrier with lots of paper towels to soak up the urine, so it won't slosh out of the carrier onto my seat. This way it only smells bad for the rest of the trip!
matttail
Car: 2007 Nissan Versa
Here's a great link, that may offer better or cheaper solutions than buying a commercial cleaner.
http://www.news.cornell.edu/re....html
Great for other stains too.
Scuba Steve
marleyfan wrote:Whatever Scuba Steve. The only reason I mentioned it is that it may have made a difference in the cleaning process. Can you say conclusively that the Versa SL (2007) does NOT have memory foam? How do you know? I have provided several references which indicate that it does. The fact that none of them are from Nissan does not mean they are not correct.
Here is a product that I use for my hockey equipment, shoes and car floors it works wonders and never had any odors after the applications. Truce?
Modified by Scuba Steve at 11:36 PM 8/29/2008
marleyfan
Scuba Steve wrote:Truce?
Damn were we at war? I hate when a truce is called before I even realize I was in a war.
Thanks for the suggestion. I have a feeling I may be trying several of the ideas. I bought a bottle of stuff specifically for cat urine and emptied like half of it on the seat. Still smells of cat pee. I'll keep trying.
Althalus
Car: '07 Nissan Versa Hatch SL CVT
I'm not sure, but I'd be worried about the airbag sensor in the seat when you're pouring tons of chemicals/liquids on to your seat...
marleyfan
Althalus wrote:I'm not sure, but I'd be worried about the airbag sensor in the seat when you're pouring tons of chemicals/liquids on to your seat...
Good point.
faction
Car: Versa
I just had a cat urine problem a couple weeks ago. Get an enzyme cleaner and follow directions. Worked great!
I got my bottle at Target--It was less than $10 and didn't damage the clothes my cat decided to use as his litter. (so weird, he's never done that before!)
You just pour it on, let it dry, if it still smells repeat. The enzymes keep working until the odor is gone. It might take a couple applications if it is soaked into the foam.
and I think it is fairly safe--biodegradable, non-chemically toxic.
If that doesn't work, just burn the car cuz there is no saving it!
dave01978
Car: 2009 Versa S Hatchback
I have used this before with good luck with dog stains in my cars, also use it when I do detailing as well works well.
http://www.waterlesscarwashpro...etail
