Z
Call Tom Mackin of Northwest Envirolution, Inc. and he will tell you where the nearest facility is, and will ensure that they have the correct adapters to service your engine. If it is an Nissan dealer, you are probably alright, but call first to confirm.elwesso wrote:I also plan on doing an engine flush procedure, along with a rail flush.....
Looks like I get a trip to the infiniti dealer...... Do you think a nissan dealer would have that stuff
pstickne wrote:What is an "engine flush"?
You can go 10K miles, but should you? There are some great posts on this board about oil chemistry and use parameters. Might try a search.__________________Brian1995 Q45 & Q45t & 2000 Q45Altiman94 wrote:2k per oil change is pretty good Wes. You can go 6k with synthetic easy.
