Holding at a constant RPM the motor usually doesnt misfire. It seems it will only misfire under stabs of the throttle or under load, perhaps because its in boost. Its hard to just hold the motor in boost you know lol. I'm pretty sure the black spark plug of cylinder 2 means its probably there, now I'm not 100% sure, I've seen more dumb things than this. My theory is a stuck open injector on that cylinder, although I've never seen it... it would cause a rich misfire on that cylinder and a black spark plug, even if the ignition system were working properly. I cant imagine anything else causing a misfire and still ending up with a black plug.eh? wrote:To be sure which cylinder is misfiring:Have someone rev the motor until it misfires. Unplug each coil pack one at a time until you don't hear much of a change in engine noise. That will be your bad cylinder.
Read the original post, there is no ignitor, but yes I've grounded the harness in many places to be sure that it is good.robbie2883 wrote:just to toss it out there but have you ran separate ground to the igniter and the coils?
This is a good idea, but it still doesn't mean that he doesn't have an actual mechanical problem in the injector itself. All you are doing here is checking the "coil" side of the injector. This does not test the actual opening/closing of the "plunger" inside the injector. But nonetheless, it is a quick and simple check that needs to be done, just not as conclusive as it is thought to be.S14-NEO wrote:if you have a multimeter, check the resistance values across all six injectors...all you need to do is to measure across the two terminals in each injector..it will give you a good indication if you have an injector that is starting to flake out on you...
missed that part...sorry...but i wasn't talking about grounding the harness. i was referring to grounding the actual body of the coil pack. you'd be surprised what a coil pack can do if it's not grounded properly. just a suggestionDriftingisLame wrote:Read the original post, there is no ignitor, but yes I've grounded the harness in many places to be sure that it is good.
Thanks guys-Max
I'd go to .8mm first and see how that goes.. that's the commonly accepted sweet spot for RB motors.dfddfd2 wrote:Plug gap at .9mm might be the problem. Try .7mm.
