devil_child »
https://forums.nicoclub.com/devil-child-u58421.html
Sun Apr 06, 2008 7:15 pm
I was looking in the fsm because I'm having maf issues all of the sudden.
In the MAF section it shows the shielding being grounded. Where does this ground to? If mine isn't grounded can I take some wire, solder it to it, and ground it to the chassis?
here's the problem, If i unhook my n62 it runs but rough (like the maf is unhooked duh). if I plug it in, it starts, runs, levels off at 700, sputters and dies. Fuel pressure for that split second is fine. vac at 700 is at 19-20. The tune is fine. Plugs are new. Ignition cool. tried an n60 on different settings, nope, j60 nope, same effect.
Voltage is at .59 and 1.2 when blown through. The e-manage measures it at .2v in and out.
What I'm thinking is that the GN coil's magnetic field is creating interference. But does that create a difference in voltage? I don't know exactly how that works.
i was going around a turn in my neighborhood when it started to screw up on me....
