CA19DET wrote:it may have 6000 in parts in it, but no offence D, i would take the TOMEI built one anyday, even it it wasnt bored and stroked.. TOMEI like TODA has a great rep for building great crate motors. and with they attention to detial and precise machining, knowledge of parts etc, i would think there is allot more in this engine than jsut parts.. i think the headwork and GTiR valves, and porting etc is worht allot..
PS - i got the TOMEI gears too theya re hot.
PPS - whats in your motor thats worth over $6000 USD??
Personally, I wouldn't buy anything from overseas that if something went wrong, I couldn't go back and argue about workmanship because no one is perfect. But Tomei's reputation is what it is and of course a little man on the block such as myself can never and will never try and upstage their quality. When I saw your cam gears, that's what made me get me a set. They are well made and look 10x more sturdy than the HKS new school pieces.
Okay, what's in my motor is only around $4000, but over $2000 in machine work is what makes me call this long block a $6000 work of art. Include in this engine is:
JUN Camshafts 272 intake w/10.5mm lift and 272 exhaust w/10.5mm lift
JUN racing valve springs
Jun Solid lifter kit
Titanium retainers
Head is meticulously machined so that the camshafts' lobes can clear the head.
Head is meticulously ported and polished
Valves are ground and reseated
Wiseco Pistons (stock bore)
Pauter Rods
Rotating assembly is balanced
Crank is polished
New oil pump
New water pump
New seals
Modified oil pan
New timing belt
Tomei Adjustable timing gears
NISMO 1.2mm headgasket
ARP headstuds
ARP mainstuds
What's sitting in garage:
MSD 95 lb/hr injectors
SDS engine management system
Custom sheetmetal intake manifold heavily polished
Custom fuel rail
Ford Mustang 73mm T-body (modified)
Adjustable fuel pressure regulator (not NISMO fpr)
Custom turbo manifold
HKS big wastegate
Blitz dual SBC boost controller
K-sport coilover kit with adjustable pillowball upper mounts
Brembo drilled and slottet rotors
Nissan Maxima brake booster
Custom rubber over stainless steel brake lines
NX2000 big brake set-up (new)
Nissan maxima gearbox with helical LSD
Custom CV axles
Walbro 255lph fuel pump
Vital Gauges
Custom strut tower brace
And a few other riceboy things that have consumed my hard-earned $$$s
Dee
