phil_z_purrfanity »
https://forums.nicoclub.com/phil-z-purrfanity-u11078.html
Thu Nov 06, 2003 1:43 am
Thanks for the insightful info re. my initial questions.
Now it is official, cracked head............
I have check at the Car-Parts.com site for both a head and a complete engine.
From my service manual I see that the ideal compression for this motor was between 151-179psi with a maximum variance between cylinders of 14psi.
The car parts website has heads going from $175-$350, which is very reasonable in comparison to what the mechanic was guesstimating, he's a Volvo guy, so I don't think I'll have him do the work in any event.
The car-parts.com also has complete engines from $400 up to I'd suppose a grand or more , anyway some list properties such as OD, ST, RWD, FI.....so I'm assuming that there are parameters within which certain engines for certain models are interchangeable. So to my Questions, and I appreciate the opportunity to pick your so comprehensively informed brains!
1. Is there a resource online where I can enter my vin# and get the true specifics of my engine?
2. Are AT and ST not interchangeable assuming I retain the AT I now have?
3. Will a ST and accompanying transmission go into my car w/o complicated modifications?
4. What are the tests I should ask be performed to check the conidtion of a used cylinder head(not rebuilt, but from a wrecker)
5. What are the test I should expect to have been performed to check the condition of an engine from a wrecker? And what are the optimum and indicative of a "pass on that one" results of those tests?
I guess that's all. It is a wonder that you guys are here, thanks~ :bowdown:) :bowdown :bowdown :bowdown :bowdown :bowdown :bowdown :bowdown
