hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Wed Jun 01, 2005 4:03 am
one more thing... i have only seen one instance where the turbo broke in two pieces, and i'm sure everyone knows what instance i am talking about... it was on some honda forum.... it was a different turbo than the one in this kit... i have an ssac kit and have had no problems with the turbo i got thus far. i've had it on my car since the end of january. the only problem so far is that there is a small exhaust leak, but i have not yet determined if it is because the manifold has a crack (which i do not think is the case, because i can't find a leak anywhere) or if it is leaking at the seal between the manifold and head, which is most likely the case. i have not yet removed it to find out but i will do so soon.
i bought my kit as a starter kit, and it has done fine as a starter kit... if i wanted something more advanced i would have bought something with more potential and a better reputation and better customer service...
as long as you don't treat this kit like something it's not (it's not a high dollar bullet proof kit... it is a starter kit, which means it's probably not something that will be good for 400 hp. period. the end.) you will have good results i think...
