gthammers »
https://forums.nicoclub.com/gthammers-u19435.html
Wed Jun 06, 2007 1:17 pm
Yes,
Have you pulled cams, chains, sprockets?
Cam to crank timing is set when you apply the chains. (Re-read my earlier post about moving the crank with the cam chains off, please)!. If you set to match the pics all is good. Then stab the distributor, and watch your counting direction for plug wire location. #1 is front and going CCW 3,4,2. If you go the wrong way you swap 3 & 2 and it barely runs, won't idle, smells like incomplete combustion and can really piss you off. Unfortunately I speak from experience...
Did you get the FSM sections I sent you?
