oneslow240se wrote:easy out looks like a drill bit that is tapered but catches counterclock wise...... bascially if you have a stud/bolt or screws thats broken and or sripped flushed with the surface you would use this method to remove the remaining piece......
but to further elaborate, you have to drill a hole into the broken bolt and then hammer the easyout into it. because of how it catches you can then put a wrench on it and simply unscrew it. drilling the hole is the hardest part.
they have saved my *** a few times.
