This is why you should always replace the used water pump...
BlackZ28629
Picture speaks for itself:
Some may get lucky and get one that is clean(er), but mine apparently saw a lot of salt and rust. I flushed and cleaned the entire cooling system...New WP installed!
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Mine still looks brand new, but recently the seals went out... about 80k miles later. Lol
That's pretty nasty though.
I usually recommend for people to remove and at least inspect the pump before swapping in the engine.
At least doing the water pump on a rwd sr is easy.
BlackZ28629
true, it would be a very easy job replacing it in the car..I almost didn't even check it; so glad I did!
