This is what I'm thinkin for my engine build.. whats your opinion
95s-14
Car: 95' 240sx/se
Well I've had my s14 for alittle over 3 years and over the past year I've had nothing but **** luck w/ my s14 SR swap. I bought my motor from Jazzpro (they suck serious ***) and when I got it in it had a bad turbo and rod knock. I had it rebuilt since I din't have the time or know how to do the build myself and 2000 miles later it spun a rod bearing at a drift event.
I got the motor torn aart this week since I've been taking my engine class at school i feel better about doing it myself. When I got it apart I noticed that two of the rod bearings were backwards in the rod ( the oilhole in the bearing was on the opposite side of the oil hole in the rod). Now I'm doing it myself with alittle help from my auto teacher and these are my thoughs n what I wanna do LMK what you guys and girls think
MODS:CP pistons (not sure what compression ratio or bore I want yet)Eagle rodsACL bearings NEW OEM CrankCouple new NissanOEM odds and endsARP studs/ bolts everywhere (already have headstuds)Apex HGLigtweight pulliesBC step 2 cams (already have comp springs in the head)HKS adj cam gearsPeak Boost top mount turbo maniT3/To4e 60 trim turboTial 38 mm wastegatePeakboost turbo elbow (already have 3in DP back exst)Greddy intake maniTomei 60mm throttle bodytop feed fuel rail 740cc or 850cc injectors (not sure yet)greddy oil panoil filter relocationApexi Power FC D-jetro
ummm I can't think of anything eles right now but I'm tryin to push 400whp on low boost and close to 450whp on high boost
lmk what ya'll think it's gonna be along build cuz I a in a co-op program for school i work in a chevy dealership 8weeks then i go to school for 8 weeks for 2years and when i'm in school i have no means of income at the moment. and i'm paying for all this by myself as well as doing suspension and body during this build
any helpful opinions would be great or advice car will be a weekend play around car and track car not my primary car but if i'd like it to be able to be driven to ATL,GA (6hr-ish drive) to see fam if I want so needs to be reliable
thanks again
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
New Oem crank? Got a link to this? everything sounds good but with that turbo I am sure you could hit some decently high numbers.
95s-14
Car: 95' 240sx/se
my buddy has the info on the crank I'll try to get it for you
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
95s-14 wrote:Tomei 60mm throttle body
Stock sr TB is 60mm
srdub-t
Car: white 91 SR22 powered coupe 240sx, 95 black c36 amg
im pretty sure stock is 50mm, you can get a s13 na sr20de throttle bodey and thats 60mm and bolts right up
95s-14
Car: 95' 240sx/se
supreamS14 wrote:Stock sr TB is 60mm
sorry I looked again the Tomei is 70mm my bad
White Comet
Car: fc, s13 and mazda6, Sierra
srdub-t wrote:im pretty sure stock is 50mm, you can get a s13 na sr20de throttle bodey and thats 60mm and bolts right up
will one off of a us spec fwd sr work? like from a sentra se-r?
TRBOMOFO
Car: S13.5 built redtop
be careful reading your crank and block for your main bearing grade # and colors so you order the right size
i was able to get rod ACL bearings but not main ACL bearings so got fresh OEM
if you find some let me know i would like to upgrade
95s-14
Car: 95' 240sx/se
TRBOMOFO wrote:be careful reading your crank and block for your main bearing grade # and colors so you order the right size
will dothe machine shop is gonna measure for bearings then i'm gonna double check it at school aso i'm getting the whole rotating assembly balanced so it'll be smooth as silk
crashcourse
Car: 92 nissan 240sx-hatch, 95 240sx- coupe
You have almost the exact setup as what I am running. I went cheap and didnt replace my front cover/oilpump untill this last rebuild. I strongly advise you to get a new one if you havent already. I spun all my mains and one rod.
You should definitely hit 400hp on that setup . My spring is set to 18psi I havent had it running long enough to get it to the dyno but, It will stay door to door with a 600cbr rr from a 40 kick till 6000 in fifth its just a laggy turbo but great up top,(5000 on)
Hijacker
Car: '92 240sx Convertible
'94 F-150
He won't be able to use OE rod bearings since he's going with aftermarket rods. Anyways, a shop can easily mic up the bearing thickness and order the bearings from ACL or where-ever they order through. Since you're using brand new parts, you should be able to get bearings that are a bit on the tight side of the tollerances and will help oil pressure.
Personally, if the crank wasn't damaged much, I would consider having it turned and using undersized bearings.
95s-14
Car: 95' 240sx/se
the crank was turned on one journal before and it looks like a pile of **** so i'll pro just get a remaned for jgy customs
