this is such an embarassing question, but im gonna go ahead and ask
91nissantwo40sx
KA24DE 144k milesN/A
So this is my first manual transmission car. Only god knows what the hell is wrong with my car because i clearly do not know sh1t if the noises i am getting from my car is normal or not. So i have a picture here and this is what its like everytime i shift gears. The "red" mark is when the engine gets loud/screams and does not like to give much power.
***Whenever i am on first gear, from 0 RPM to 2000 RPM the engine screams and my car starts to vibrate. Its kind of annoying each time i start rolling the car.
Am i good to go or am i an idiot?
IcedOut13
Car: 1991 240sx
im going to say ur engine mounts are probly pretty bad first of all possibly the transmission mount too...the screaming part im not sure though
themadscientist
Screams? something like "YES, YES, THAT'S IT, GIVE IT TO ME DADDY"!
Seriously though check your belts first and tell us what you find.
Dattebayo
You need to record the sound in video or something dude. Then get a photobucket account and post it here.
Rusted_PS13
Car: 1991 Nissan 240SX
Clutch slipping maybe?
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
Weird, my engine screams at 0 rpm too!
Fenvy
Car: 2005 350Z Base 6MT
that's you screaming like a little girl, not the engine
ashibah83
Car: 93 SUPA BLACK COUPE
fan clutch???
dickie
Car: Killer Turtle
power steering pump or effed up ac... something attached to the motor by the belts like tms said.
dickie
Car: Killer Turtle
and by the way, this is the LAST TIME i will move one of your threads to the tech forum.
stop posting duplicate threads with the same question and stop posting in the wrong forum or they will be REmoved.
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
mine was screaming like that too.but then it started screaming around 5 rpmi just bought me a prestone belt dressingit will do the job
lbrowne
My money is on the belts as well.
albert_ey
Car: 2007 Nissan 350Z
I agree, buy some belt dressing, it's cheap. Then check your mounts.
bakero
Car: 1999 Firebird
Check belts and then check your clutch. Could be something sticking and realeasing at 2k rpms. If it's your master or slave, you might as well replace both. my bet would be the belt though
1sikS13
Car: 1992 S13 240sx
bakero wrote:Check belts and then check your clutch. Could be something sticking and realeasing at 2k rpms. If it's your master or slave, you might as well replace both. my bet would be the belt though
