kouki-gymkhana »
https://forums.nicoclub.com/kouki-gymkhana-u9464.html
Mon Dec 20, 2004 5:13 pm
Yes, the FSM was very helpful in terms of showing you where the critical 5 mounting bolts are located. It doesn't tell you, however, how f*cking difficult it is to uncouple the side defroster vents or how to angle the instrument cluster surround just right so you can shimmy it out without cracking it. You know, little details like that... . The FSM is also useful for showing you where the mounting pawls are for those cursed switch modules (headlight, hazard, dimmer, cruise, etc) so that you at least know where you should be squeezing.
