pheonixS13KA24 »
https://forums.nicoclub.com/pheonixs13ka24-u5201.html
Thu Jan 29, 2004 8:00 pm
What's up guys... This may be a freak situation, but someone please let me know if they have had this same problem:
I just installed my KYB AGXs and Eibach Prokit struts/springs, and my car rides significantly stiffer. Most bumps send jolts through the chassis. This is not a problem, for I have them set for stiffness and it doesn't bother me. My fuel pump, however, apparently hates it. When I drive over medium sized bumps/dips/holes in the road, it seems as though my fuel pump briefly comes disconnected from its power source and makes contact once more after impact. My fuel is cut for only a few milliseconds, but it is enough to make the car jolt and sputter. At low RPMs, (i.e. when I'm coming to a stop and put the car into neutral) if I happen to hit a bump, the car will die as a result of the cut in fuel. It's just annoying! It just started today... Any suggestions?
P.S. I have no idea where to locate the wiring for the fuel pump! (It's in the gas tank, I'm sure, but I don't want to mess around with electrical unless I have some dirrection!)
