Kaikias wrote:Sounds like the noise my car was making when it had really low oil pressure, there is not enough oil pressure to put tension on the top chain. Causing the chain rattles against the top of the cover or chain guide. Could explain the spun bearing. When my car started making that noise I took of the valve cover and could see the chain move 3 inches up and down when I gave it gas. Sorry about the motor
^Gah. Yes. The majority of timing chain issues that occur after the top two useless guides are removed is from bad oil pressure and lots of gunk keeping the tensioners from moving freely. The KA my bf pulled from his $500 fastback (jealous--yes--but my coupe is nicer) had 160k on it. We have no idea what happened to it. Although the lower guide he removed was seized up, so I suppose it was that, the rods were fine, the valves/bearings were fine. Time to go KA-T
Tiger, nice to see another female member (one that isn't an attention whore/ditz, lol) Planning on putting together the SR? I guess that's a given. Good luck!
