NewfoundlandDude wrote:Well I have a WarpSpeed -Y, but I also have a Cali-Spec so it doesn't remove the Front Header or pre-cat. My Y-Pipe ends on the horizontal on the bottom of the front pre-cat, as opposed to vertically on the bottom of the header like a fed-spec.
Yeah, I have fed-spec so I eliminate both. Might want to think about investing in some headers.
NewfoundlandDude wrote:I may try grounding the knock sensor for a tank of gas, and see what it brings. Are there any ill effects from this? Are there any known problems that may happen when I ground it? And where can I find info on what resistor I can use instead of grounding the KS???
I think the only ill effects you will find is if you run 87 with a bypassed knock sensor. I believe Nissan put the knock sensor there to deal with the growing number of bafoons who didn't take the dealership's instructions seriously when they said to use 91. If you use 91 all the time, bypassing the knock sensor won't hurt a thing. As far as the resistor goes, I wouldn't do that unless its necessary, like if the knock sensor goes bad. Until that happens, just ground the knock sensor somewhere on the engine where it can't bother anybody
