This a Smart Idea?
RedRum240
Car: 1990 240sx Fastback
Putting adjustable springs on kyb agx's? I dont want my car to be high. and I dont want it to be moderate. I want it to be low.. will this cause problems? and if so what problems? and what can I do to prevent these problems? need to know asap if possible thanks guys.
BadMojo
Car: 2007 Mazdaspeed 3
RedRum240 wrote:Putting adjustable springs on kyb agx's? I dont want my car to be high. and I dont want it to be moderate. I want it to be low.. will this cause problems? and if so what problems? and what can I do to prevent these problems? need to know asap if possible thanks guys.
Not sure what you mean about adjustable springs, but folks use stuff like the Eibach Sportlines with KYB AGX. I'm sure it's going to shorten the life of the shock (and void the warranty on them) but you may still get acceptable life out of them, depending on your driving habits/road conditions.
As far as I know, other than a full coilover setup, your only other real choice would be some Koni Sport shocks. They would probably handle the drop better than the AGX's, but they're going to be a PITA to adjust and install compared the AGX's. Also, they're still not designed for the even more limited travel that you're going to have.
If you're going really low, you should really have a short stroke shock. Problem is, nobody sells them in the US market. I know some guys around here found some KYB Buzz Specs on Ebay, but they're expensive.
You'll also need to do something about your alignment when you lower the car as much as it sounds like you want. How low *do* you want to go?
silkk
Car: 94 B13
89 S13
07 S2000
like ground controls?
if so, those are fine
but if you're dropping it more than 2 inches, you'll need camber kit
RedRum240
front and rear camber kit? if so can u provide a link to where I can get both? I have camber right now with 35 % tread on the tire expoised to the outside of the xcar. and negative 10% on the inside practicly haha
