mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Wed Feb 06, 2008 7:33 am
Signal should be coming from the distributor so I'll check the wires at the distributor and make sure there isn't any corrosion at the plugs.
I've rarely, if ever, seen the gauges go out but if you don't have any luck at the distributor it would definitely be worth checking out.
