The synchro's in 3rd and 5th go bad on almost all Z's. Not serious if your under warranty.axh941 wrote:Sooo heres the story. I Recently got a 03 350z Enthusiast with only 12k miles cheap. I know too good to be true. So While I'm driving mostly down shifting into 3rd gear, it grinds even though i have the clutch down all the way. The Grinding noise happens while I'm throwing the stick into 3rd gear. Once I'm in third gear the noise is gone. Lol not only does it scare the crap out of me but its also embarrassing driving people. Because i always get that question, "you sure you know how to drive this thing?" I bought the car off a used Nissan dealership and got an extended warranty. But just to make me feel better anyone know what the problem could be and how serious is it? Thanks in advance!
I have an 08 with 5600 miles and have posted several threads about clutch problems. Nissan just replaced my clutch, flywheel, slave cylinder, through out bearing (and drive shaft do to a lazzy mechanic) under warrenty. call 1800-nissan-1 to complain about your problem it took me about two weeks to get the issue resolved. I am still having problems with the new slave cylinder and through out bearing though.amanda22 wrote:350Zs have serious clutch issues. To my knowledge, and from my experience, they're not covering clutch replacements under warranty. I've even filed a claim with Nissan that's been denied.
is 009 referring to the code on the transmission? if i were buying a transmission from a totaled Z and wanted to make sure it was a 009 do i just ask them to read the code stamped on the transmission?_b.jaye_ wrote:damn. good stuff to find out... well, luckly, i opted for a 48/48 warrent through the dealership.... if they throw in garbage, itll be their arse!
