thinking of using 9:1 forged pistons.......
JayPat83
any arguements? $500 shipped with rings .020" over.getting motor back soon. got a matching cometic h/d head gasket, ARP bolts, fidanza 9 lbs fly,comp clutch, 550's with top feed, custom v-mount fabricating up right now.
RMiller
Car: BBQing
You know the argument of high vs. low compression. Compression is bad for boost, but good for everything else.
klattr1
Car: GT42R powered S14/KA
9:1 will be great.
JayPat83
if klattr1 says it is ok then it must be!!!!! dude, we need to meet up sometime. i have been following the progress on your car from the beginning and it is toooooo phat.
also, klattr1, where can i get some top feed 550's for around $300 or under? i am having the hardest time locating some.
Redline240
Car: 95 240sx
JayPat83 wrote:where can i get some top feed 550's for around $300 or under? i am having the hardest time locating some.
Good luck, under 300? be sure to let me know where you find em for that...
Redline
Structure240sx
top feeds are cheap. call RC engineering. 50# msd's come out to 525cc and can be had for $250 almost anywhere u go
JayPat83
so rc 50's will work for my app.?
JayPat83
got my injectors in today and my pistons should be here very soon.
