DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Tue Aug 02, 2005 12:05 pm
i was researching this alot before, and the only reason i declined on doing the side exit exhaust was because of the frame rail. I don't know if you have an s13 or an s14, but i know on the s13 the frame rail pretty much keeps you from exiting right before the rear tire. Maybe instead of exiting the side, dont cross the frame rail and just put a turn down in the middle of the car. its not uber-race skyline tight, but its a lot like a B-race pipe, and thats kinda uber tyte right? I'm just messin around, but i definately considered this as an option.
If you route the side pipe out behind the rear wheel i dont think you're going to get the look you want. If your car isnt lowered at all you might get away without ever crushing the pipe too bad. I've seen 240s with driver side exit pipes, so dont get me wrong it definately can be done, but you have to consider that frame rail.
I know someone will probably bring up square tubing, or oval tubing, and thats not a bad idea, considering the size of the piece you need to make the side pipe is only like two feet long with like one 45 degree bend
Now if you're talking about building a real side pipe, one big nasty one that goes along the entire side and only crosses the frame rail right by the drivers front wheel, then figure out how to route that exhaust and do it to it, cuz you'll be my hero
