thinking of going KA-T
DrifterBoy240
Car: 1991 nissan 240sx
well for starters i am thinking of going KA-T and looking at getting some opinions on how should do it.
like should i get a spare KA long block and build it up and swap it in when its done.
or can i just do it in a weekend wen i have all parts on hand and ready to go.
and some opions on what style turbo header to use? which header is better SSAC vs. peak performance?
i was also jsut thinking of running a stock SR20DET turbo (T25) is that a decent turbo for the KA or do i need to get a bigger turbo?
and what all do i need as far as the ECU goes will a SAFC work or should i get my ECU tuned by rs enthalpy?
sorry i know everyone has seen these post before but my computer wont load the search page, so sorry for my ignorance i just want to know what i am going to need before i get into this.
480sx
Car: 1996 Pearl White 240sx
Your spare block idea is a good one, if you have the cash do that. It lets you work on the engine separately while you still have the ability to drive your car. Lower the compression of your engine, replace its timing chain, head gasket ect.
I have an SSAC manifold, and i would recommend against using it. After i saw the quality and heard the stories from NICO about people who used it, i upgraded to a better manifold. You could probably get away with using it for a while, but ultimately it is going to be your cars weak link. I have heard that the wastegate flange blows off the manifold under boost. (two separate occasions to the same person) However for the price....
A tuned ECU is your best option in my mind. While a SAFC is soo easy to use, you have to have an onboard wideband, or spend alot of money at a dyno and have them tune it for you. Also, with a SAFC you have no timing control, so you are limited to under 10 pounds of boost or so.
I have heard a t25 is pretty inefficient on a KA, the KA after all is a 2.4 liter. A t3-t4oe hybrid turbo is the best sized turbo for our engines.
Hope this helps..
DrifterBoy240
sweet thanks man that really did help me out alot because my car is a DD so i think i will build up a spare block.
partymonster 975
Car: 03 Maxima SE, 94 Corolla
like above, spare block is smart, AMS has a rebuild kit that seems would work great for you. I'd get a larger turbo, especially if ur rebuilding, you will be happier in the long run, I'd go for a t3/t4e or the AMS GT32 or GT33. That's personally me though. As for manifold I like JGS. good luck with ur build and s-afc will be fine for a little but while u have it get urself an ECU tune and the s-afc can work out any kinks in it. Good luck with ur project. Since it is daily driven and your not totally rebuilding u would pull off 300whp with the same turbos and have fun in a safe limit zone. Same stuff applies, just get a thicker head gasket (I rec. fel pro). Sorry for the scattered info.once again good luck.
Riubens
Car: ka-t 240 and 99 Q45 t
am running a t25 om my set up now and am loving it, matched up with my fidanza flywheel a beat stock sr20's runing 14psi with my car at 10psi,but I have a spare block now that am saving for a ams rebuil kit amd plan on running a ams gt32 in the near future but as of now am happy.
DrifterBoy240
sweet thanks guys the info was great cant wait to put in a turbo.
what oil/coolant lines does anyone recomend?
PapaSmurf2k3
Site Admin
JGS sells a nice kit for that too. http://www.jgsturbo.com Good luck man take lots of pictures and keep us updated.
DrifterBoy240
thakns will check them out after work today.
and i am moving down to mississippi by like may so i wont be able to start the project until mid summer or it will be a nice winter project.
Chezedik
Car: 1991 Nissan 240sx
You should buy my setup. It's in the sig.
Florida240sx
at least get a t3, however those t25's act like superchargers on ka's
DrifterBoy240
Florida240sx wrote:at least get a t3, however those t25's act like superchargers on ka's
but how would the top end be if it spools so quikly? im looking at drifting/ auto-x the setup.
Chezedik
Top end will suck, since it becomes a major restriction at high rpms.
DrifterBoy240
Chezedik wrote:Top end will suck, since it becomes a major restriction at high rpms.
okay what about the T28 "disco potatoe" turbo? is tha decent turbo or shoudl i still go with a t3/t4e or the GT32 or GT33 from AMS.
and what make better headers the log style or the mandrel bent kind from SSAC?
Chezedik
Disco potato is still a little small GT2871r is good. Personally, if it were me, I would go with GT3076 or GT35r.
DrifterBoy240
okay, sweet thanks for the info on the turbo's now i just need to worry about getting the oil/coolant lines and how to get those on. but im sure i will find a write up if not that will be my next question.
Chezedik
Seriously, check my sig, I am selling all of that gear (WG, turbo, dump, mani, intake, and oil lines/coolant lines) for 650, thats half of a turbo kit! You can buy the intercooler with BOV, and all for 1000.
Just look at the sig, so I don't have to advertise in here.
DrifterBoy240
i know i checked it out its all some really good shiz-nit but i really cant do anything till after i move i think i posted that earlier in the post.
Chezedik
That's cool just keep an eye on it, if you need something later, holla...
DrifterBoy240
no prob man will have to keep you in mind when i get some cash for the turbo build.
Florida240sx
Chez....Manifold,Turbo,Wasteagte,Oil Lines, and downpipe for 650... [email protected]
Chezedik
Sorry, decided not to sell.
DrifterBoy240
why are you not selling it now????? or are you waiting for a certain someone to get some money to buy it?????
