Thinking of getting nitrous for my sr. Good or bad?
kornmanz
Car: 89 240sx Hatch SR Powa'd
So I'm coming up with all the funds needed to finish my car in the next few months. To finish my setup I want to do the following:
Upgrade the turbine to a Gt35r w/ bigger injectors. LSDand a roll cage
Was thinking of putting nitrous in my car. Good idea or bad on an SR? I have a built bottom end w/ stock pistons. I was only thinking like a 50 or 75 shot.
adrianfromthecastle
Car: 1992 Nissan 240sx
I don't see why nitrous would ever be a bad idea. Safe and reliable hp if done right... why not?
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
I say go for it. Just do it RIGHT!
xX RB Xx
Car: SE3P, FC3S, FC3C.
leesredgt wrote:I say go for it. Just do it RIGHT!
do a wet shot.. stay away from dry shots.
Dittoz7
Car: 1997 2f0WtY SE!
Just Stay Away From The Asians With Teh Uzis!
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Not many people dry shoot 50 or 75. A wetshot seems like the only choice for a little juice.. I don't like N20, but its safe as long as its done right with the correct tune and safety devices. My tuner runs a 500HP dryshot on his car making over 900 to the wheels and its safe all day (at the track).
Sileighty_85
Car: 1991 180SX
Got a buddy who Put a 100 shot on his completly Stock single hammer slammer. **** was funny its like VTEC when he sprays.He needed a new clutch though.
S13_love
Dittoz7 wrote:Just Stay Away From The Asians With Teh Uzis!
Clawhammer
kornmanz wrote:I have a built bottom end w/ stock pistons.
Did everyone else miss this??
What is 'built' then? Everything else? Cause you skipped over the like weakest part of the SR bottom end...
I'm confused.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
i saw that too and was hoping he meant stock cr pistons.... Hopefully because who goes through the woes of a bottom end only to use factory cast pistons.
Sileighty_85
Car: 1991 180SX
I wouldnt really call the pistion the weakest part, the whole stock bottom end can support up to 500+whp
But maybe he meant RE-built??
Mistaken
Car: 93 240sx Coupe
Stock pistons are a huge crapshoot on sr's i toasted ring lands running a whole lot less turbo then a 35r with no spray. If you have stock pistons ide say even that 35r is going to be able to max out the bottom end. Now if your using the spray for spool with a nitrous express progressive control, ide say go for it, just do a wet shot to be safe. There is an article somewhere on the internet about someone using a nitrous spool on a sr20.
Btw he is using a new set of stock pistons with eagle rods.....
hugogos22
Its kind of funny u ask this question theres not alot of information on sr's running juice on any of the forums.Juice is great. Run a wet shot from company like nitrous proflow, NX and NOS all make great wet kits. The reason i recomend wet is so you dont run into any problems leaning out. You can just sit there and tune you AFRs with your wideband by just rejetting you fuel. Nitrous and turbo cars make a great couple just ruuning a 35 shot you will gain 45 to 50 FT pounds of torque. It will put a lot more muscle in you power band were you need it the most in its mid and low end. So if your running lets say a 35r with a .82 exaust side. And your doing a 45 roll. You could by a window switch and spray a 50 shot from 5000 rpm and have it shut down 7000 rpm and let the the turbo do its thing up top. It would help you a **** load spooling the 35R . This is a great read on spray and SR's. http://www.importtuner.com/fea....html
kornmanz
Going for a wet shot. Thinking of going with a zex kit.
This is my setup:
Greddy titanium valve springscrower titanium valve setcrower 272 cam set (also getting a 264 duration cam)phase 2 motorsports rocker arm stopperspro-machine acid treated headpro-machine multi angle valve jobpro-machine ported and polished portsARP head bolts and studsHKS 1.04mm multilayer metal head gasketbrian crower bronze valve guidesOEM valve seals (new)OEM timing chain tension-er (new)5 Ziegen Oil cap
Nismo rod bearingsNIsmo main bearingsNismo thrust bearingsEagle h-beam rodsOEM pistons (new)OEM rings (new)OEM oil pan (new. Got replaced because other one was dented)Greddy blow-by canisterARP rod boltsGreddy aluminum pulley setgreddy oil filter sandwitch plate
Aeromotive tsunami fuel pumpaeromotive 100 micron inline fuel filteraeromotive fuel pressure regulatoraeromitve fuel pressure gaugegreddy fuel pressure fittingsBGRG custom high pressure fuel lines with 6AN fittingsApexi SAFC 2 fuel controllerZ32 Mass air flow sensor
Nismo thermostatSamco braided radiator hosesgreddy radiator capkoyo polished aluminum radiator12" electric fan (2)Phase 2 motorsports aluminum coolant tankB-road carbon fiber air diversion plateAEM air filter
Stock turbineGreddy turbo timerGreddy Profec b Spec 2 boost controllerBGRG steel braided oil return lineHKS equal length exhuast manifoldHeat solutions exhaust heat wrapJDM lab aluminum intercoolerJDM lab intercooler pipingBlitz BOVBlitz BOV fittingApexi DownpipeApexi dual N1 Exhaust systemOEM o2 sensor (new)
Z32TT dual piston front calipers2 Z32TT brembo rotors2 240sx brembo rotors (rear)2 phase 2 motorpsorts steel braided brake lines4 tokiko performance shocks4 tein s performance springsFR and RR began racing strut tower braces
Sileighty_85
Car: 1991 180SX
Mistaken wrote:Stock pistons are a huge crapshoot on sr's i toasted ring lands running a whole lot less turbo then a 35r with no spray.
Sounds like a Tuning error or someone in Japan was beating the **** out of that engine before you got it,Like I said the Stock SR bottom had been know to hold up to 500+whp
Hese a Vid of a Stock SR Engine only bolt ons and and some JWT Cams with a GT2871R
Mistaken wrote: If you have stock pistons ide say even that 35r is going to be able to max out the bottom end.
Of Course seeing that the 35r is capable of 600hp and the stock bottom end can only holds 500hp
Mistaken wrote:Btw he is using a new set of stock pistons with eagle rods.....
Thats kinda a weird set up why upgrade rods and not Pistons?
kornmanz
I did not build this engine.
The guy I bought this car off of is named Dino Crnkik. Or something like that. He's a douchenozzle. He did stupid **** to this car. I'm trying to basically re-build it and finish it with a large student loan I'm getting.
huggys13coupe
Car: 91 coupe
put forged pistons in it and run a 125 or 150 shot
xX RB Xx
the piston rings on a sr take a **** above 375 hp..
maybe you should come over to the usa.. and try out one of ours/yours sr..
it might be diffrent over in japan land.. but i highly highly doubt it.
LeroyBrown
Car: 1995 nissan 240sx s14 blacktop
kornmanz wrote: re-build it and finish it with a large student loan I'm getting.
FTL
kornmanz
LeroyBrown wrote: FTL
What?
xX RB Xx wrote:the piston rings on a sr take a **** above 375 hp..
I am in the USA dude. ?
LeroyBrown
kornmanz wrote:
What? The student loan.. i was jk. what is the interest rate on that.
That guy thinks new mexico is Mexico....
kornmanz
^alot of people do lol.
LeroyBrown
what is the interest rate on that student loan?
Clawhammer
He's talking to the guy in Japan defending SR pistons..
Sileighty_85
Car: 1991 180SX
well tell that to guy in the vid that i posted who put down 400whp on his stock pistons.
xX RB Xx wrote:maybe you should come over to the usa.. and try out one of ours/yours sr.. it might be diffrent over in japan land.. but i highly highly doubt it.
Your joking right? where the hell do you think you get your SR engines from?The US never produced an SR20DET. All your SR20DET's come from here in Japan.
Clawhammer
Just because that guy put down 400whp on stock pistons does not mean every SR can. I mean I understand what you're saying, don't get me wrong. But I've read multiple times about SR ringland failure, etc.
A local guy here has the record for stock KA bottom end at like 535whp or something like that. That doesn't mean all KA's are now magically good for up to those numbers. I mean he blew up like eleventy motors just getting to there. And then he blew up the record motor and has now built one.
Sileighty_85
Car: 1991 180SX
Clawhammer wrote:Just because that guy put down 400whp on stock pistons does not mean every SR can. I mean I understand what you're saying, don't get me wrong. But I've read multiple times about SR ringland failure, etc..
I have never heard of this, I've been working on SR's for over 5 years and never heard of an SR Internal failure under 500 hp unless the car was poorly taken car of and inproperly tuned, Now RB25's thats a differnt story
Clawhammer wrote:A local guy here has the record for stock KA bottom end at like 535whp or something like that. That doesn't mean all KA's are now magically good for up to those numbers. I mean he blew up like eleventy motors just getting to there. And then he blew up the record motor and has now built one.
well that was just a freak of nature KA...oh i guess not ppl slap on GT2871R's and run 400-450whp on Stock Bottom end SR's all the time
when ppl are looking for 500+ these ppl go ahead a build it to with stand that. Like me, Mine will hold 700+ whp but I only need 400 cuz thats enough for drifting for me.
painengaged
Car: s13 sr20det
please dont put in nitro
