Future_gohan wrote:Tire wear isn't that bad, i daily'd my 300whp 240 with a welded diff for 3 months and I only went threw two rear tires, and i do burn outs all the time, and all that stuff. So it isn't bad if your not stupid, I'm about to drive an sr powered coupe with a welded diff daily, and I'm not changing it out till winter. winter you might want a vlsd.
Exactly, how much u got in your pockets right now??? Seriously a dif here is like 60 bux at the jy and shouldnt take u longer than 30mins to snatch off. Check your local jy'sI wouldnt. I had one a hated it. Save you money and pull a 300z vlsd from a junk yard or send me the money and Ill do it for you.
i got about 300 bucks right now, maybe youre right and a junkyard might have it, everyone says its bad because of the tweetin or squeaking and others say its not bad. Maybe a welded is the way to go, i mean i dont have to worry about snow either really i live in forsyth county GASxMachine wrote:Exactly, how much u got in your pockets right now??? Seriously a dif here is like 60 bux at the jy and shouldnt take u longer than 30mins to snatch off. Check your local jy'sI wouldnt. I had one a hated it. Save you money and pull a 300z vlsd from a junk yard or send me the money and Ill do it for you.
What?? 300 bux u could snatch a few of em!! Dude i live in gwinnett co. Head to pull apart north, they have like 3 or 4 j30's right now alone. Snatch a spare if u like to rebuild, tweetin and squeakin my arse. Change the oil, bolt it on, good 2 go.got about 300 bucks right now, maybe youre right and a junkyard might have it, everyone says its bad because of the tweetin or squeaking and others say its not bad. Maybe a welded is the way to go, i mean i dont have to worry about snow either really i live in forsyth county GA
OHH YEAAAA BUDDYtroskinatior wrote:Now heres the biggest question.
Do you plan on drifting?
troskinatior wrote:Ok, good. Because there are some people who dd with a welded and don't even drift.
When I get a welded I'm not going to daily it, I'm going to switch out the diffs at the track because I work long hours and I get out at after 12pm so I don't feel like thinking about driving.
I know all of the drawbacks of a welded diff and the only thing that concerns me is spining out because I'm not always going to have good tires. I also want to do alittle sprinted driving once in awile and I don't want to worry about spining. And its not like it takes that long to switch them out anywayTheRealNap0le0n wrote: as long as you drive like a normal human you never have to think about the car coming around on you in the rain or dry. As long as you keep decent tires on it it'll be fine.
You were driving the black coupe right? When did that happen?Justin35ll wrote:just be carefuel who you have do it and make sure they do a good job.
I'm on my 3rd welded diff already in a season and a half.
I hope this one holds up i just swapped it in 2 days ago
