Thinking of buying this SR. . . Need some advice.
Jagstang
Car: 1995 S14 w/ Kouki S14 SR20DET
Hey, today I checked out an S13 Blacktop SR that's in a rough shell, and It has unknown km's. It supposedly had 70k km's back in 2006 when purchased, so by now, it probably has 140+ km's.
Here's some details on the motor. It hasn't been driven for 1 year. . . The S13 didn't have a hood, so the blacktop was exposed in a garage all year (lots of dust on it etc). Oil is old, and the fuel is old.
We did a cold crank compression test on it by removing the fuel pump fuse, and keeping the throttle body wide open, and cranking it with and without all the spark plugs in. Here's the weird part. At first it was reading 95 PSI across all 4 cylinders. . . They were all pretty dead on. . . At the time, when we did this, we forgot to press down on the gas pedal, so we redone it with the gas pedal pressed in.
The results were basically the same. So we put some oil in the cylinder and it brought it up like about 8 psi. . . At this point we noticed that there's probably not much air entering the intake, so we removed the OEM tubing (that's connected to the side mount), and managed to bring it to 120 PSI. . .
So my question is, I understand these numbers are VERY low, but the guy told me he's been in a LOT of SR's, and tells me this one is clean, idles smooth, transmission is smooth, power is still very strong (all this a couple days ago, he bought the car from a friend and drove it to his house which is 2 mintues away).
So is the reasoning's behind the low PSI numbers due to the the old oil, and the 1 year old gas, let alone it sitting for a year (valve seals sticking)?
And is it a possibility that the engine may have had some work done to get the lower PSI? Such as an aftermarket Head Gasket, and forged internals etc?
He said he was going to drain the old gas out tomorrow, and idle it for a long time and warm it up, and then re do the compression test. I wonder if that would make it more normal? I
Anyways, here's some pictures of the actual SR.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
I'm going to ignore the lowness of the numbers and say that it's good they're all the same across the board. A lot of SRs have sat in warehouses and junkyards for years. Then, they are shipped to the states where they sit in another warehouse. The important questions here are:
What does he want for it?
What do you want to with it?
Forged internals won't lower your compression, but a thick headgasket will. I don't see one, but most headgasket companies have a portion of the headgasket stick out the front where you can read the brand name. (COSWORTH for example.)
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
buy my sr. im tired of the d*mn thing sitting in my garage
mattaltima99
Car: 1999 Nissan Altima KA24DE, Spectra Cold Air intake, OBX 4-1 Headers, OBX 10.36 Spark Wires, Flowmaster super 44
how much you want for your SR? anything wrong with it etc.
s13drifter88
needs clutch, turbo and tune. the 2871 is on my ca now, the clutch is fried, will need tune for the z32 maf and the rc 550's. it has the hks step 3 cams, complete crower valve kit, arp studs, cometic street pro gasket set, grex oil filter relocation, rc 550's, hks fuel rail and b&m short shifter
mattaltima99
sweeeet how much?
s13drifter88
3500. wiring is already converted for a USDM body too
