thinking of buying a vert???
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
so far i have 2 hatches and have had one for 3 years. i like verts, but ive heard that they flex alot expecially with high horsepower, since i would prob swap an ls1 or rb into it... any other things i should be foreworned of before i go and find one...
BOOMSHAKALAKA
Make sure that:the top is working properly up and downwindows are workingtransmission shifts wellpop up headlights workengine is running...no severe problems
everything else is basic when you would search for a used car
heartofaskyline
bump on the flex problem....chassy flex with high (300+) hp
BOOMSHAKALAKA
heartofaskyline wrote:bump on the flex problem....chassy flex with high (300+) hp
Flex is not that serious as most people would think...people assume so because it's a convertible. Vert frames were reinforced to accomodate the top and have stiffer suspension than the coupes or hatches.
A man that knows a lot about this is wirelessalpha...he uses his vert for drifting. Also Greg (AZhitman) has a vert himself...maybe if sees this thread he will give you some info also.
Modified by topless94 at 11:03 PM 10/24/2006
heartofaskyline
ok thanks. i had a buddy that said they tend to flex, but maybe he was wrong. then agian, i could always just weld some pipe across the frame
