knightrider »
https://forums.nicoclub.com/knightrider-u3208.html
Wed Aug 17, 2005 9:36 pm
as was stated before, the ca didnt come with a stock recirc, they didnt add this until the SR20. do not disconnect your wastegate on the turbo, you will blow your motor or not build boost at all if your lucky and the accuator rests open. adding a recirc is not that hard, tapping into the stock rubber suction pipe is easy, its rubber, just be sure to seal your hole with silicon sealant.
also, consider buying a bosch recirc valve(iirc its a dsm recirc), they cost about 40$ and they are for recirc only, the problem with most bov is the spring is too stiff to accually function correctly like rex and f3600 bov's. the bosch unit is opened with the slightest bit of vacume, helping response under vacume and eliminating all surge. venting your bov is ghey in my opinion and really just to show off. tap the vacume signal behind the throttle plate, preferably the FPR line or any other suitable port.
Modified by knightrider at 12:46 AM 8/18/2005
