thinking of buying 2010 M35
skatastic
Car: 2010 m35
I'm thinking about buying a 2010 M35. The M35 that I have my eye on has navi but not DVD. I've read through the owners manual online and it doesn't appear to mention A2DP bluetooth streaming which I assume means it doesn't support it. Is that the case? If it does have A2DP can the car's controls control the music (ie. pause, skip, etc)
I see in the owner's manual that it says that the IPod player only charges the IPod touch 1st gen model but in the compatibility list it doesn't list the touch at all, does the touch work and do the newer generations really not charge?
Assuming the IPod touch works would Pandora work and could it be controlled from the steering wheel and/or center console to skip songs? (Luckily I have hotspot on my phone)
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
I'm guessing it should be the same as my 08... No Bluetooth streaming, the iPod touch is supported (If you have the connection inside center console where dvd usually goes)but does not charge (still an easy solution via Amazon schoche? adapter) Charges it without a problem. The Pandora feature is via Web so that only works via the audio/video connections facing the back seat coming out of the center console(if yours is equipped with that)! Mine is ADV. TECH package so it comes with all possible connections, rear dvd, IPOD, hard drive etc. I'm really not sure what the Tech only package leaves out from the ADV. TECH... But look for those connections I mentioned!!! :gotme
