1.) All Infiniti VH and VK V8 use chain. They are interference engines as they must be to attain high performance.greenwar wrote:I have read a lot about the 2nd Gen Q and am wondering what are the common issues with this vehicle?
1.) - does it use a timing belt or a chain. if it uses timing belt is the 4.1 an interference engine?2.) - does it have the in-famous nissan coil failing issues3.) - does it have the in-famous nissan fuel injector failing issue4,) - Reliability wise what is your opinion5.) - is the transmission a dog like many of the first gen Q45s
6.) I am leaning towards getting an ES300 or a GS300 due to their reliability. How would you guys rate the Q45 amongsts these two in terms of reliability. I don't want to end up spending 2-3 grand a year just to keep the vehicle running.
7.) Also please post your average gas mileage in city driving. I am not expecting much 18-19 in city driving is perfectly fine as I live within 5 miles of work.
8.) Also please point me to a link or post things which I should pay good attention to before buying a 99 Q45.
1.) Only on pre 1994, and it was not overheating per se, rather inadequate heat exchangers. The FY33 is worse in that regard, and all Q45 are recommended to have auxiliary ATF coolers (B&M 70268 or 70264) installed. Read Skibane's excellent post on by-passing the FY33 coke can in the bottom tank OEM heat exchanger and subsequent fluid pressure measurement.greenwar wrote:1.) I know G50s had an issue with transmission overheating. Does the FY33 have adequate cooling for the transmission? Ofcourse I don't plan on racing it.
2.) Didn't quite understand this. Are you saying plan on spending 1.2 to 1.5 grand after acquiring to bring everything up to OEM condition?
3.) I went to the dealer to ask if they do any pre-purchase inspection. The manager told me they only do visual inspection (he says it is comprehensive which I doubt) for $70.00. Any suggestion on how I should go about getting a senior technician to do an inspection?
The GS is a staright six, iron block, and a bit underpowered.greenwar wrote:I am still however considering an Acura RL and a GS300 - both v6 ofcourse..
Doesn't sound like there's anything left to replace!!Price and pics.greenwar wrote:OK Secured my Q45 today. Its a 1999 Q45T silver with black interior - with 107,000 miles approx.
Here is what was done to it:
1) All drops of fluid was changed by dealer at 102,xxx.
2) struts, shocks, springs, tension rod, ... every worn suspension part has been replaced - thats what dealer record says - $3700 job
3) AC idle pulley, ac clutch has been replaced..
4) Fuel filter replaced - fuel induction system entirely serviced - dealer record says - I am assuming it means everything has been cleaned including injectors.
5) Read O2 sensor replaced
6) Engine and other rubber mountings and bushings has been changed - not sure what that means... I will confess
7) Brand new 4 Bridgestone turanza LS-v 225/50 17 tires with 4K miles
8) Door rubber seals replaced
9) All head lamps has been replaced by the dealer
10) Everything inside seems to work except from the rear motorized sunshade
Most of these were done at 102,xxx miles.. O2 sensor was changed at 70K. Vehicle has almost no scratches - there are some slight bumber marks
Dealers senior technician was there when I went to pick up the history - he mentioned that there is nothing needed in the car. Car was at the dealer right before I took it for a test drive to get the headlamps and ac clutch etc changed. Dealer service manager was also very positive about the upkeep of the vehicle.. So I decided not to get the senior tech inspection..
Seems like a great car. So I decided to purchase it.
Looking at all the service histories - wouldnt you guys say that I don't need to get anything done on it? Just fill up and drive??
If you guys got any suggestions, I will appreciate it.
"Member's standards vary." - Q45techbullittandy wrote:"Slightly bent subframe" doesn't sound like a deal breaker to me.
Was transmission fluid mechanically exchanged? Or just drain and fill?greenwar wrote:Forgot to mention the price: 10K straight. Its a little higher than book value, but with all these repairs done, I figured I have already saved 2k.
maxnix wrote: Was transmission fluid mechanically exchanged? Or just drain and fill?
What you feed is a four wheel alignment print out from a Hunter alignment machine.greenwar wrote: This is a worrying issue, I went again yesterday and drove the vehicle once more at highway cruising speed - vehicle run very straight and no hint of pulling or steering deviating to any side.
I checked tracking as well, seems to be straight. Just to be on the safe side I will talk to the service manager and get an idea...
Thats what I expect from an experienced Q45(s) owner. Thanks Maxnix. I will get that before going forward any further.maxnix wrote:What you feed is a four wheel alignment print out from a Hunter alignment machine.
Appreciate your input.
greenwar wrote:
