skunkmonkey wrote:dude... honestly, think about what you are planning on doing with your car. it's a 1.8l motor... so if your planning on trying to make huge hp numbers... this probably isn't the motor to go with. it's old, you should rebuild... most don't, it craps out on them, then they complain the motor is crap. i could go on and on... but yeah...
no, you don't need to tune if you swap it out with a sr t25. with stock boost you don't anyways.
coilpacks tend to burn out, because of how it was designed. crank angle sensors crap out too... it's old, it's expected. a $280 replacement too... you can always find used... but you know how that goes... who knows how long it's gonna last.
there isn't as much aftermarket support for it either, but there is enough for what you'd want to do. it's a fun little motor, but it has it's limitations like everything else.
wow lots of miss information there......
yes it SHOULD be rebuilt, If bought a motor out of the junkyard in the US I would rebuild it........ why would japanese be any different?
there are several people out there who have built big and reliable numbers out with their CA, and IMO the stock motor is far better suited than any soda can motor for reliable 300+hp. with a little head work and pistons you are set for even more.
what aftermarket part are you in search of? the stock intake or exhaust manifold...... both have shown to be soild for atleast 350whp consistantly. come to think of it there are very few things I could think of that there isnt someone who sells it off the shelf(or atleast did at one time). the difference is there isnt an overabuance like SR s***.(I would rather have quality over quanity ANYWAY)
I have 2 CAS up for sale right now and used ones are very easy to locate. Asuming you even run one....... as you dont need a CAS with megasquirt anyway and is nearly as cheap as getting a tuned ECU and a decent working harness.
what limitations are there for a CA? I mean other than its need to induce more air than it is physically able to do? The ONLY limitations are budget and QUALITY tuning.
Ps coil packs wear out....... so do plug wires.........
