C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Apr 23, 2004 9:13 pm
As I've said in the KAT forum, I see no reason it wioll not work on the OBD1 S14. The MAF and the injectors are the same part. This is the crucial parts needed to make the E-Manage work. It does not tap into anything else. Given the major hard parts of both cars are the same, the tuning should be very similar or the same as far as the air/fuel tables. The timing signal should be the same as well. I speculate Greddy only lists it as a 96 and up as they may still look for CARB approval. They may not try to get the certification for the 95 model since it might be more complicated due to the OBDII transition that year.
