rgk »
https://forums.nicoclub.com/rgk-u245656.html
Fri Jul 10, 2015 11:35 am
Is there a VIN on the dash?
CV boot and 4wd shift can be serious issues, but hey: this is a site where people fix things. Are you sure it's the CV and not the steering rack? Oil drips from the cooler onto the rack boot and kills it. Replacing the rack boot is easier than the CV boot. If it is indeed the CV joint, and it has been that way for a while, prepare to buy and install a new axleshaft.
Is it a manual or electric 4wd shift? Hard shifts with a manual might mean low transfer case or transmission fluid. Are you saying it is stuck in 4-LO? And the owner is driving it around like that? I wonder, then, does the 4wd even work?
I guess you might have meant you shifted it into 4-LO, but couldn't get out of it. Yeah, that can be tricky sometimes. Could the owner get out of it?
What is this maintenance light? My 3.5 does not have one. Is it the SES? The SES is a check engine light.
Bad crank sensor is easy to replace but will cause all sorts of strange trouble. Make sure it's a bad sensor, and not bad wiring. Nothing worse than chasing bad wiring.
If the 4wd works, and it's the steering rack boot, and the crank sensor is indeed bad, haggle. You might have yourself a deal.
