EW »
https://forums.nicoclub.com/ew-u28959.html
Wed Aug 27, 2008 2:08 pm
The A Series amps have been replaced by G series. As stated above, the 8" is 4ohm. With a 4 ohm 8", I would use the G4500 instead of the two amps you listed -or- change sub to a 10W3v3-2ohm. For 8", JL's ported enclosures work well too. Different models are built different places.W3v3, W6v2, W7, TW5 made in U.S.A.Some mids & highs germany, some asiaJust too expensive for most companies to build amps here unfortunately. Always has been good stuff. Still is good stuff. There will always be "the new hotness" but JL continues to make good stuff even after "the new hotness" is no longer hot. As for crutchfield, you can get a better deal locally.
