ppastos wrote:Which is easier to clean the EGR or the throttle with TCS?
The EGR is pretty simple to remove. I've taken off a TB with TCS and as I remember I came out bloody. Either component is nothing more than righty-tighty, lefty-loosey and no adjustments or fine tuning is required to put it all back together.
You'll need basic hand tools for the EGR- a 1/4" or 3/8" ratchet wrench, a 10mm (or 12mm socket), and a 10" crescent wrench for the nut on the large pipe to the manifold. When you're done you'll wonder why you waited so long. For cleaning there's tons of posts but the basics seem to be brake parts cleaner, toothbrushes, bottle brushes, a long flexible rod for the pipe and lots of elbow grease. An easy DIY.
ppastos wrote:......Is it OK to clean one thing at a time say the EGR on day the throttle the next and the IAC next week or is better done all at once?
It's OK to do one at a time and you'll find that the IAC cleaning will go pretty quick also. IAC R&R uses the same wrenches, plus pliers for the hose clamp, as for the EGR R&R. There was a recent thread about it (one of yours?). Get the IAC gasket and do all 3 on the same morning so all the gashes on your arms will heal at the same time. You'll keep reopening your wounds and bleed to death if you tackle this three weekends in a row.
ppastos wrote:I have 2 gaskets on hand the thottlebody gasket and the EGR gasket........Do I need 2 TB gaskets or just one because I have Traction Control?
It's a long, curvy path through a TB w/TCS and unless someone says differently I think it would be difficult to clean properly without seperating the 2 throttle bodies. I have a TB w/TCS in my shop from one of my parts cars so removal can't be too difficult. Get a second gasket. In fact, get a complete 2nd set of gaskets (IAC/EGR/TB) in case you find yourself needing to take off the plenum at a later date.
ppastos wrote:I have never worked on an engine in my life besides checking fluds and changing the air filter.........and not having touched anything major just from reading this board and the FSM on spare time.
You've got to start somewhere and all 3 of these components are pretty easy to get to. You've done you're reading so print up instructions and pics, use good tools and have at it. It's not rocket science (I should know).
