ztommyx wrote:that truck is clean!
if it comes with the plow, then get it... you can make a few bucks plowing snow during winter.
No just regular filter and oil changes...Rager wrote:
is there any mafor maintenace that would be coming up around the 100k mark that i should be worried about?
Rager wrote:i think im going to go for it...........
No thats normal the truck should be able to stop pretty good considering the size. The pedal is soft, but there should be no play. But yes that is also a problem that GM has never been able to really figure out the rear brakes 1999-2004 (disc) end up crapping out which is why if you look at the new trucks 6/2007-present they will have rear drum brakes.Rager wrote:sooo tomorrow im going take the truck ofr final drive. any last words of advice, things to look for, ect? oh the brakes felt kinda soft, no grinding, just a little play in the pedal . and no real "bite" but i had no problem stopping . . it might be just the way it is. there is another 1500 on the same lot and im going to drive that and the green truck to compare.
300ZXttZMAN wrote:No thats normal the truck should be able to stop pretty good considering the size. The pedal is soft, but there should be no play. But yes that is also a problem that GM has never been able to really figure out the rear brakes 1999-2004 (disc) end up crapping out which is why if you look at the new trucks 6/2007-present they will have rear drum brakes.Rager wrote:sooo tomorrow im going take the truck ofr final drive. any last words of advice, things to look for, ect? oh the brakes felt kinda soft, no grinding, just a little play in the pedal . and no real "bite" but i had no problem stopping . . it might be just the way it is. there is another 1500 on the same lot and im going to drive that and the green truck to compare.
Some 2005 to 2007 models have drum brakes but not all mostly just crew cabs.
You seriously have nothing to worry about if you buy the truck and anything goes wrong after the 12 months all you gotta do is call me. I have everything for that truck litterally everything and if there is something I don't have i'll buy a couple complete trucks from an auction cause that means its time to get more parts.
